This morning, I found my Framework 13 laptop (Intel Core Ultra 7 155H, running Ubuntu 24.04.4) with an orange charging LED despite being plugged in for ~9 hours overnight. It refuses to power on when unplugged from a power source.
Here is some framework_tool output:
% sudo framework_tool --versions
Tool Version: 0.6.5
OS Version: Linux 6.8.0-136-generic #136-Ubuntu SMP PREEMPT_DYNAMIC Wed Jul 1 21:53:05 UTC 2026 x86_64
Mainboard Hardware
Type: Laptop 13 (Intel Core Ultra Series 1)
Revision: MassProduction
UEFI BIOS
Version: 03.06
Release Date: 08/08/2025
EC Firmware
Build version: marigold-3.0.5-a5f07f8 2025-08-06 07:01:52 marigold1@ip-172-26-3-226
Current image: RO
PD Controllers
Right (01): 0.0.0A (MainFw)
Left (23): 0.0.0A (MainFw)
Intel Retimers
Left: 0x270 (624)
Right: 0x270 (624)
CSME
Firmware Version: 0:18.0.15.2518
Recovery Ver: 0:18.0.15.2518
Original Ver: 0:18.0.5.2141
Laptop Webcam Module (2nd Gen)
Firmware Version: 1.1.1
Touchpad
Firmware Version: v0704
NVMe Device: /dev/nvme0
Model Number: WD_BLACK SN850X 2000GB
Firmware Version: 620361WD
% sudo framework_tool --smartbattery
Place your right index finger on the fingerprint reader
Enter unseal key in hex (e.g. 04143672), or press enter to skip:
Device Name: FRANGWAT01
Manuf Name: NVT
Serial Num: 0364
Manuf Date: 2024-06-25
Chemistry: LION
FW Version: Device=0x0045 FW=09.03 Build=0x4900
Mode: 0x6001
Temperature: 32.0C
Voltage: 8.898V
Cell 1: 3.651V
Cell 2: 2.525V
Cell 3: 0.000V
Cell 4: 2.722V
Current: 0.000A (avg 0.000A)
Charge: 0% (0 / 3821 mAh)
Design: 3915mAh @ 15.480V
Bat Status: 0x4AD0 [FD (Fully Discharged), DSG (Discharging), INIT (Initialization), RCA (Remaining Capacity Alarm), TDA (Terminate Discharge Alarm), TCA (Terminate Charge Alarm)]
Cycle Count: 360
=== Battery Health Analysis ===
Status: GOOD (with notes)
Note: Terminate Charge Alarm active
Note: Terminate Discharge Alarm active
Note: Battery is fully discharged
Note: Cell imbalance: 3651mV difference (>100mV)
Summary:
Cycle count: 360
Capacity: 3821 / 3915 mAh (98%)
Current cell balance: 3651mV spread
% sudo framework_tool --power -vv
Battery Cutoff: Unknown
Charger Status
AC is: connected
Charger Voltage: 17800mV
Charger Current: 80mA
0.02C
Chg Input Current:4464mA
Battery SoC: 0%
Battery Status
AC is: connected
Battery is: connected
Battery LFCC: 3821 mAh (Last Full Charge Capacity)
Battery Capacity: 0 mAh
0. 0 Wh
Charge level: 0%
Manufacturer: NVT
Model Number: FRANGWA
Serial Number: 0364
Battery Type: LION
Present Voltage: 8.897 V
Present Rate: 0 mA
Design Capacity: 3915 mAh
60.604 Wh
Design Voltage: 15.480 V
Cycle Count: 360
Battery charging
Battery level CRITICAL!
% sudo framework_tool --console recent
[6878.871800 found battery in disconnect state]
[6879.121100 Batt disconnected: reg 0x7fa1 mask 0x0002 disc 0x0000]
[6879.122400 found battery in disconnect state]
[6879.370700 Batt disconnected: reg 0x7fa1 mask 0x0002 disc 0x0000]
[6879.372000 found battery in disconnect state]
[6879.621700 Batt disconnected: reg 0x7fa1 mask 0x0002 disc 0x0000]
The laptop wouldn’t even get past the systemd startup while I had the charge limiter set to 90%. I reset my UEFI settings to default to get it to reach the desktop. Manually disconnecting and reconnecting the battery did not change the behavior.
I tried to update the BIOS to the latest 3.07 version, but without a working battery, I’m blocked by system power requirements:
% fwupdmgr update
Devices with firmware updates that need user action:
• Intel Management Engine
‣ System power is too low
• System Firmware
• UEFI dbx
How can I fix this issue so my laptop can charge again?
