I’ve had my Framework 13 Pro for a couple of days so far. So far it has been working pretty well.
One thing I have noticed is that while the keyboard is largely silent, the spacebar has this awful click when it bottoms out. It seems significantly more prominent on the left hand side of the spacebar, and it doesn’t seem to depend on how hard you press the key.
Hi, I can confirm that the spacebar on my 13 Pro is significantly louder than other keys, mostly due to the large metallic stabilisers. I haven’t found it distracting though and the perceived difference is en par with other keyboards I use. Also, it gets louder if I hit it harder. So, if you have a particularly loud spacebar, something might be broken. You probably already tried this, but first I’d apply even pressure on the whole bar to make sure all the clips are in place. I that didn’t help, I’d contact customer support to see if your spacebar has a physical defect, because I believe FW specifically discourages users to disassemble and repair individual keys themselves.
I did have some luck just pressing the key in (slowly) over and over again. I found that I had two points of engagement. The first sounded like a normal key press, the second is this awfully loud clack. There is very little difference in depth between the two sounds. I was able to trigger the loud clack with very minimal movement of the key, so it wasn’t related to how hard I was pressing.
After fiddling with it a bit like that, I noticed the sound disappeared. Oddly though, the RHS started to pick up the sound. I think after applying pressure around all the edges of the space bar it is now much better. I’m keeping an eye on it though because I’m not convinced it’s fixed.
I’d describe the sounds as:
Letter keys - light pitter patter
Shift - audible actuation
Space - hollow clack on key bottom out
Space is sounding more like shift now, which doesn’t have the cheap/irritating sound. I’ll fiddle with it a bit more and see if it’s actually good .
I hope that fixed it for you, then. Maybe the spacebar was not clipped in all the way. If the problem reappears I’d definitely contact customer support, since you probably have a damaged clip and/or debris under the spacebar. (Key travel should be smooth with a distinguishable actuation point at the very beginning of the key press and no additional point of resistance midway. Anything else points toward a mechanical defect.)
