I just bought a Laptop 13 AMD Ryzen™ AI 300 Series main board, and the cooler master case for it. Framework power supply, adata ao1v56wc8w1-bh3s ddr5 8gb ram x2 and all that’s happening is it light are blinking never going to the bios or anything. I want to use this as a frigate host. It does have a blink sequence it does but I can’t upload a video. So it is blue → red (this just keeps repeating ) → white → red → green - 4 → red - 2 → green - 4 → red → orange → blue - 3 → green → blue - 4 → red → blue → then repeating blue and red slow flashing
I think all you need is a CMOS battery.
Also, the first time it boots it does memory training that can take up to 15 mins.
Got a battery and it’s still doing the same thing. I think it may be the ram, at least I hope it is. Going to continue down the trouble shooting I do get fan spinning now, but still no display out of the usb type c port,
Well also tried it with a ram stick on the confirmed to work list and still nothing. So I lift it plugged in for like an hour or two the plugged the display in and who know why but it was booted. Maybe the ram sticks or maybe just the screen not turning back on after the power saver mode turned on
