This is partially a case report, as I know the solution (get a new USB-C module). Posting in case this information turns out to be useful.
I began having issues with my USB-C charger: the back-left USB-C port no longer could be used for charging. (/sys/class/power_supply/ACAD/online is 0) and usb devices do not seem to be recognized (no entries in dmesg). Swapping another module into the same port seems to have fixed the issue, meaning the issue is in the USB-C module. Spraying with compressed air did not work, and I see no visible obstruction in the connector. The back-left port was my primary port for charging.
I am not sure what the cause of this is, but I did recently purchase and begin using an Anker 317 Macbook Pro charger (100W). On the off chance this did damage my module (e.g. if other reports have been seen of this) I would definitely want to know!
NixOS
Which release version?
24.11
Which kernel are you using?
6.12.0
03.04
Which Framework Laptop 13 model are you using? (AMD Ryzen⢠7040 Series, IntelĀ® Core⢠Ultra Series 1, 13th Gen IntelĀ® Core⢠, 12th Gen IntelĀ® Coreā¢, 11th Gen IntelĀ® Coreā¢)
13th Gen intel
