Hi there, I just received my DIY edition intel u-series framework 13 and completed its assembly. However after trying to power it on, the screen wouldn’t turn on or show any indication of booting up, and the two side LED’s kept blinking red. I then noticed thanks to a community post that the black foam pad that is supposed to press on the chassis intrusion switch was missing (though it is nowhere to be found if it did peel off by itself). I then tried to switch on the device while manually pressing the switch, and still couldn’t get the screen to turn on. What should I do?
