Framework 16 - 5070 - Not recognizing display plugged into it
Which Linux distro are you using? Arch (EndevourOS)
Which release version?
(If rolling release, last date updated?) Today
Which kernel are you using?Zen
Which BIOS version are you using?4.02
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series) 7040 series with 5070 GPU.
When I plug my VR (Valve Index) into the USB C port on the 5070, it doesn’t recognize the device at all, when I plugged it into the 7700s it was always recognized. Not sure if I got a dud card or what? I updated my drivers, and it just won’t see it. I am also on Hyprland. The only way to get the 16 to see the Index is by plugging in the DP to one of the ports on the laptop that support the video out. Anyone else running into this issue or have any suggestions on things to try?
