Hello all.
I am trying to install Linux on the framework 16. I successfully installed Ubuntu 20.04 on it. The problem is that I absolutely hate ubuntu and want to change it now to my preferred distro Linux Mint. I’ve read elsewhere that the recommended ISO is version 21.3 Edge, so I downloaded this into a flash drive. When I insert my flash drive in the FW16 (powered down), and I go to the bios it cannot see the flash drive. It just gives me a blank screen or the ubuntu options. Is there a fix to have the FW16 see my flash drive? I believe this might be related to updating the bios which I was unable to do again because I cannot boot from the flash drive.
Try another expansion slot? There have been reports on some USB sticks not booting from every slot. [RESPONDED] Issue with booting USB from port 6
Try both BIOS pages (press F2 or F12 repeatedly during boot). Disable secure boot?
yes, i’ve tried both F2 and F12 with similar results. Yes, i’ve disabled secure boot.
Interestingly, when I switch the expansion slots, it can now see the drive, but when I choose boot from file, it opens files explorer into a empty screen. Perhaps I need to do something specific to the drive? I even reformatted it fat32, so the only file on it is the ISO.
Also, The flash drive is 16 gb usb type-A, if it matters.
I don’t think you can boot the ISO. You’ve got to flash the ISO to the stick and should see a normal file system.
Uh you need ro “burn” the iso to the flash drive. You can use balenaEtcher for example to so it
Ah this is the step I forgot. Thank you both. Let me try that now.
Yep, that did the trick. FW16 was able to boot up to Linux Mint after I burned it on the drive. Thanks again.
You can set up ISO Boot in GRUB2, so if you want to have multiple ISOs just copied onto a drive, that’s certainly possible to set up, but it requires manual configuration.
If you just want to set up a drive for a single installer, using a utility to flash the disk image (ISO) to the drive is probably the best way to do things
