Framework 16 rgb lights don't turn back on after sleep
I just got my framework 16 laptop, and got everything set up and working.
I just have one minor annoyance: Every time I close my laptop lid (it’s set to go to sleep on lid close), and re-open it, the rgb lights on my keyboard don’t turn back on. I can still use the keyboard though. Just the lights won’t turn on.
I’ve looked online, and I can’t seem to find anything about this. None of the Fn key combinations do anything. I’ve re-seated the keyboard. Even messing around in VIA at keyboard.frame.work couldn’t get it going again.
The only thing I’ve found that fixes it is a restart.
I’m on Windows 11 24H2.
Any help would be appreciated
Welcome to the forum!
Can you try disabling and reenabling the device in device manager?
If that doesn’t work, try reinstalling the driver bundle from the Framework website.
Well … I am now happily annoyed.
The problem seems to have fixed itself. No idea how or why.
Thanks for the suggestions though.
I’m having the same problem. It affects both the RGB keyboard and the RGB Macropad. I can get the lights back on by opening the catches and sliding the trackpad out far enough to reboot them. I was doing QMKwork on them, so this has become something I’m used to doing, but it would be nice not to have to.
same here, on Linux though - Keyboard backlight won't turn on after sleep. Thanks for the tip on sliding out the trackpad! annoying, but faster than a power cycle.
Same problem here on Win10 x64. It’s firmware issue I think as keyboard backlight does not recover neither after sleep or hibernation. I wish it would work like on Dell XPS - once set to on at requested brightness it works every time you reboot, recover from sleep or hibernation… It’s quite annoying when you work in low light environment… I hope this will get fixed as it’s an issue from first days afte rthe release and nothing gets done about it. Trackpad trick does not work on Win OS…
I have same problem,
I’ve found when the Keyboard lights don’t turn on, if you close the screen count to 10 then open the screen again it seems to then wakeup keyboard lights.
Assume its some kind of driver/firmware issue.
Let me know what is needed from a debug/collection perspective, happy to provide logs, debug info, etc to help get to the bottom of the issue.
I am also having this problem. It does not happen for me with the RGB Macropad, however - its backlights come back on after sleep, but the keyboard doesn’t.
Using Fedora 41 (Aurora). Also tried without the macropad. Only fix for me is briefly sliding the touchpad out and back in.
