Framework 16, I have even replaced my cord with ltt 240 W charger cord. After I did a quick check up on my computer battery and it was destroyed after less then a year I have been focusing on my Battery more often and I have found that even when plugged in and the computer is reconizing the brick it sometimes decides not to charge at low charge but it doesn’t let my computer die and i have reset my bios settings to try to see if that was the issue. its stressing me out i dont want a ruin another wonderful battery. I am on arch linux. It might be the bios. or I might be doing something shit dumb. I just want this fixed ![]()
If the led next to the cord isn’t turning on then you likely tripped the USB protections and that port was turned off. You can get it back by going into bios, hitting the disconnect battery button, and rebooting.
There are a lot of threads similar to this, I recommend searching the forums for those other threads.
If your battery is destroyed within a year it’s better to contact Framework support for warranted replacement
Thank you so much! its been stressing me out!
yes I know that thank you, I have already gotten a replacement they are wonderful on that i just noticed, I think its a software issue not a hardware one.
