Framework cycles between charging and not charging
**I have a framework 16 (Ryzen 9 7940HS with GPU) Running windows 11, and I am experiencing an issue where the charging rapidly starts and stops (switches maybe once a second).
I know it is not a port issue, as I have tried all the ports (including plugging in without an expansion card). I also know it is not a charger issue because it happens with multiple chargers.
I think it seems to happen more often with higher wattage chargers, as well as when I have less battery life.
Anybody know why this is happening/how I can fix it?
There’s a detailed thread of FL13, which is related to your FL16
Please reach out to our support team so they can have a closer look at whats happening.
