Framework Laptop 12” won’t turn on
So I was using my new framework laptop 12 with fedora. I had been using it perfectly fine, up until today, but when I went to turn it on, the power button LED just stayed on for a few seconds and then would turn off. Nothing would display on the screen at all, and I could not F key into the BIOS at all. After trying a few times, the power button LED stopped turning on all together. I am sure the battery is fully charged. I’m not sure what happened or what to do. I did see the flashing error lights blinking at one time, but it never did it again and I could not remember what the error code was.
The bottom of the laptop feels warm to the touch even though I have only ever been just trying to turn it on, and it has not been running at all today.
Anyone have any ideas?
I know you said the battery is fully charged, but have you tried with it plugged in, or only on battery?
It might be worth opening it up and re-seating RAM, SSD, and checking things like the display cable and such. If you have already done that or aren’t comfortable trying those things, I would open a support ticket.
Welcome to the community! Good luck. I hope you get it solved.
For the display to not even post means that the GPU initialization is not happening, which is usually because system RAM did not initialize. Please reseat your system RAM. DDR5 5200/5600 is very finicky. (Ask me how I know, hahaha)
If your NVME went bad, your system would still post and you’d be able to get to the UEFI options, etc. Which is why I think your system RAM is the culprit here.
Something similar happened to me, but I believe it was the bug in 3.03 and earlier BIOS versions that was fixed in 3.04 (which is triggered by trying to power up soon after unplugging) - just in case this has caused it for you, I was able to get it to boot again by plugging it back in and trying again.
Thank you! Yes I ended up opening a support ticket. I re plugged everything and reseated the RAM, and now the power button LED isn’t even turning on anymore.
This is a description of the issue from Bios version 3.0.3 that was fixed with 3.0.4:
This firmware update updates PD firmware to 0.0.12 which fixes the following issue: When the system is powered down, then AC is disconnected, the power button won’t turn on the system after 10s until 30 seconds
So if it does not boot after 30+ seconds of waiting it might be a different issue.
Did this ever get resolved? I am facing the same issue right now.
Did you try reseating your RAM?
My motherboard just went bad. I never knew what BIOS I was running on the old one, or if that was even the root cause. But I just got the motherboard replaced after working with FW Support and sending them videos of the troubleshooting.
Yes I did! I reseated RAM, Memory, and the display cables.
Understood. Sounds like that will be my issue as well.
Seems I’ve run into the same issue with one of my framework 12 (we’ve got two in the family). No response at all from the machine. I’ve contacted support for a solution.
I checked the bios version when I got the machine, it didn’t need an update at that time. It seems the latest bios is from 8 juli so I should already have that bios on the machine.
Reseating memory or the ssd has no effect and there are no post codes.
edit: I have disconnected the battery for 30 seconds and inserted it again, then I got 3 time blinking red light. Still concerned about the led being red but it is booting and charging now.
Same issue here, couldn’t fix with re-seating the ram/ssd or removing the battery for a bit.
Have contacted support.
When I first got my FW 12, the included 48gb RAM stick that I got with it was faulty. When I turned on the machine I would get a power led and then nothing. The fan would eventually ramp up.
It was all the RAM. It is very particular. The RAM not working will cause display problems, because the system will not boot and the display will not function without GPU RAM being shared with it at boot.
There could be more going on, but the RAM was the issue for mine. DDR5 is a bit more sensitive than DDR4. Just keep that in mind when handling it.
Support sent out a new main board. Didn’t fix the issue. It could be the RAM, but I have no spare sticks. The laptop was on and running find on the RAM for several days thought without me going inside before it failed.
Sounds like it is the RAM. Very unlikely that a new mainboard would also be bad. DDR5 can be VERY finicky.
I’ve ordered some new ram. We will see.
On my FW 12 I am using the Crucial 64gb stick. Works great and is awesome having so much on the 12. Highly recommend.
Picked up the crucial. Fixed everything. Returned the Kingston.
I’m also having a similar problem of screen not posting on a AMD AI 300 series Framework 13. Also contacted support but reseating memory and SSD is not working at the moment.
