Framework Laptop 13 AMD Ryzen AI 300 shuts off / loses power shortly after connecting a Samsung EP-T6530 65W Trio charger. The charger does not appear to complete USB-C PD negotiation: the system
briefly detects AC, but the battery remains discharging and the UCSI power supply entry stays at 5V / 0A. After a couple of minutes the laptop abruptly powers off.
I have seen similar issues posted here, but none that the computer just suddenly crashes and powers off unexpectedly.
Firmware status
fwupdmgr get-updates reports no updates available.
System firmware:
- Current version: 773
- BIOS shown by sysfs: 03.05
What happened
I connected the Samsung EP-T6530 using a known-good USB4 240W cable. The charging LED did not turn on. The system stayed on battery, then after roughly a couple of minutes the laptop powered off abruptly.
This was not a clean shutdown. After reboot, last -x shows the previous boot as crash.
Timeline
Relevant boot:
Previous boot:
Sun Apr 26 15:20 - Mon Apr 27 10:00:27
Current boot:
Mon Apr 27 10:02:32
Events around the failure:
09:58:59 USB-C/typec device removed from port0
09:59:11 USB-C/typec device added on port3
09:59:12 ucsi_acpi USBC000:00: unknown error 256
09:59:16 system briefly switches to AC profile
09:59:17 ucsi_acpi USBC000:00: unknown error 256
09:59:26 system switches back to battery profile
09:59:28 system switches to AC profile again
09:59:29 ucsi_acpi USBC000:00: unknown error 256
09:59:47 system switches back to battery profile
09:59:52 system switches to AC profile again
09:59:53 ucsi_acpi USBC000:00: unknown error 256
10:00:27 last log line from previous boot
10:02:32 next boot starts
## Power state samples
I had a small local power logger running every 15 seconds.
Before plugging in the Samsung charger:
09:59:07
ACAD.online=0
BAT1.status=Discharging
BAT1.capacity=41
BAT1.voltage_now=15135000
After plugging in the Samsung charger:
09:59:23
ACAD.online=1
BAT1.capacity=41
BAT1.voltage_now=15045000
ucsi-source-psy-USBC000:001.online=1
ucsi-source-psy-USBC000:001.status=Charging
ucsi-source-psy-USBC000:001.voltage_now=5000000
ucsi-source-psy-USBC000:001.current_now=0
And shortly after:
09:59:39
ACAD.online=1
BAT1.capacity=41
BAT1.voltage_now=15064000
So the system briefly reports AC online, but the battery is still discharging and the USB-C source remains at 5V / 0A.
## UCSI / typec events
There was also a storm of repeated events on the UCSI power supply entry:
change /devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:001
change /devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:003
Kernel messages include repeated:
