Framework Laptop 13 half dead screen
I have a framework 13 laptop,
Everything has been good, I’ve had it for a year give or take. It has the matte screen and top amd hardware. I booted it up the other day and alm the sudden a whole section of the screen isn’t working. I took it apart, reseated the connector. It is the same in the bios, so it seems like a hardware issue rather than a windows issue. I ordered a new screen, than thought maybe i should research more. Searching on here im seeing several people are having the same problem and im wondering if there has been a solution to this yet and if this is supposed to be a warranty issue. Also curious if everyone having this issue is using the same display.
Thanks
did u ever get a sulution mines doing the same thing
Yes,
Unfortunately it need d a new screen. Easy fix, alittle pricey. Several other threads with samw issue. Good luck
is the only sulution?
