Hi everyone, first post ![]()
I’m building a custom portable laptop using the Intel Ultra 13 board and an Intel Wi-Fi 6E AX210 module, and I’m considering using the Framework Laptop 16 Antenna Module Kit. Both the Framework 13 and 16 Antenna Modules are listed as supporting 2.4 GHz, 5 GHz, and 6 GHz bands, and they both use U.FL connectors to attach to the Wi-Fi module.
However, I’m wondering if there are any potential issues or compatibility concerns using the Framework 16 Antenna Module on the Intel Ultra 13 board. From what I can tell, U.FL connectors are standardized, but I’ve heard that sometimes similar connectors like MHF4 or MHF5 can cause confusion due to their smaller sizes.
Since the Framework 16 Antenna Module seems to offer more flexibility for antenna placement (important for my design, as I’m mounting the antennas farther apart for better spatial diversity and signal strength), I want to make sure it’ll work seamlessly with the Intel Ultra 13 board and the AX210 module.
Has anyone tried this specific combination or similar set ups, or does anyone have any insights into potential issues? Any help would be appreciated!
