Framework Screwdriver Mislabeled? PH0 vs PH00
Has anyone else noticed that the Philips end of the Framework screwdriver appears to be mislabeled? It obviously works with the Philips screws that are in the Framework laptops, however when attempting to use other PH0 screwdrivers, they don’t actually fit in the screw itself. If not using the Framework screwdriver, I’ve had to use bits labeled as PH00 for them to fit, and even then it feels more snug (i.e. like it fits better) in the screw than the Framework (which itself is just a tad bit looser as there’s a small amount of play).
Has anyone else experienced this?
For reference, the other bits I’ve tried on a Framework are:
  1. LTT Precision Screwdriver
  2. Wiha PH00 x 40
