Hi there,
I’ve bought both the Framework Stylus as well as the Metapen Surface Pen M3 Pro. I also do own a Wacom One 13 (1st Gen - DTC133W0B). I’d like to share my experience with both stylus.
| Criteria | Framework Stylus | Metapen Surface Pen M3 Pro | Wacom One 13 |
| Diameter | 10.0 mm | 9.0 mm | 9.75 mm |
| Length | 16.6 mm | 16.7 mm | 15.0 mm |
| # Buttons | 2 (physical) | 2 (virtual) | 1 (physical) |
| Button position (comfort) | okay (not perceptible) (*1) | perfect | good (haptic) |
| Max. distance from screen | 7.0 mm | 8.5 mm | ? mm |
| Speed/Latency | Very good | Good (*2) | Perfect |
| Tip | Held magnetically | screwed | pressed |
| Tip loudness | clicky | rubbery | rubbery |
| Indicator light (pen is active) | No (only for charging) | Yes | - (No battery) |
| Battery replaceable | Yes | No | - (No battery) |
| USB-C port cover | No | Yes | - (No battery) |
| # spare tips | 2 | 1 | 3 |
| Look and Feel | Nice (good color match) | Good but indicator light shines through plastic casing | - |
(*1) The buttons on the Framework stylus are flush with the stylus case itself. They are only barely perceptible. It is also very hard to distinguish between the lower and upper button due to missing haptic features.
(*2) Somehow I had the feeling that the latency of the Metapen M3 Pro is a little higher compared to the Framework stylus. Writing with the Framework stylus was a touch easier due to being “more responsive”. But the difference is minimal (and may also be a perception problem - I haven’t measured that).
Personal notes
The button concept of the Metapen really worked great for me. You can just tap the stylus with your finger in order to simulate button #1 or #2. It works better than expected and feels natural after a short amount of time.
The buttons on the Framework stylus lack haptic features and are hard to find and to distinguish.
The Framework tip has some wiggle room and as such makes a more clicky sound when you tap the display. This is not loud but worse than the rubbery and rigid tip of the Metapen. I like the Metapen more as it is quieter and as such feels more premium.
The replaceable battery of the Framework stylus is a great idea!
For me personally, I prefer the Metapen Surface Pen M3 Pro a little more than the Framework Stylus. It is mainly due to the sound of the Framework Stylus and the buttons being barely perceptible.
