FW 13 AMD 7840U no fan, even after replacement
FW laptop 13 AMD 7840U fan not working under load or at idle, but does spin once on booting.
If I don’t fully seat the fan connector it’ll blow full blast, already had the fan assembly replaced
BIOS 3.09
Anyone have similar issues
If I put the laptop on my lap, it’ll cook my legs in minutes
photos and a video:
If the fan runs on full blast when not fully seated then there might be an issue with the RPM sense at the board level. Could be a bad trace, cold solder at the connector, etc. If you have not already start a ticket with support.
Welcome to the community @Scott_Mclean.
