Ubuntu
Which release version?
24.04.5 LTSWhich kernel are you using?
Linux 6.17.0-1033-oem
3.04
Intel® Core™ Ultra Series 3 (X7)
When using my fw 13 pro while connected to power for some very light browser based gaming yesterday evening, I started to hear the sound for connecting and disconnecting power to the device multiple times and with no regularity. I disconnected the power cable for the rest of the session but was able to reproduce the behavior again this morning.
Interestingly it was around 97% charge capacity and disappeared again from 98% to 99% when just looking at the device and not using it (it wouldn’t go to 100% while running it). Yesterday while using it, it wouldn’t stop making this sound until I unplugged.
The charger is the official fw charger that came with the device and I used the usb c expansion card at the top left of the device.
I should add that I also saw the battery icon switch from charging to “on battery” for a very short time while the sound was playing.
Did anyone else see this behavior from their machine as well?
