FW13 Pro Intel - Discharging, Charging & Beeping
I just got my FW13 Pro Intel and when the battery is fully charged and the charger is plugged in, the laptop will keep flipping between charging and discharging which causes a beep every few seconds. I’m running Ubuntu 24.04 which came preinstalled with BIOS 3.02. Is this a bug within Ubuntu or with the laptop?
Have a look at your Power Statistics dialogue - I wonder if it drops from 100% to the slightest bit of usage then it will go to 99% and go back to charging. I’d guess one should be able to disable that, e.g. by setting it to charge only when it loses at least X% of charge.
However I would be inclined instead to disable the charged/charging sound, and let the charging circuits do what they want. I am guessing the bleep is from Ubuntu reacting to an event, rather than a lower-level system in the laptop running an ordinary bleep.
It’s probably a BIOS bug, as the latest BIOS version is designed to mitigate this by adding a 5% hysteresis loop rather than flipping charge/discharge status within 1%
Thanks for your input Squiggler and Charlie_6. I opened a case with Framework. I’ll see what they say.
For now I disabled the alert sound within Ubuntu.
After jumping through every hoop imaginable with Framework support, it was deemed that the Framework charger was defective. When I used a 3rd party charger with the FW13 Pro, it did not exhibit the same behavior.
They ended up shipping me a new charger which so far has been charging to 100% without the constant charge/discharge flipping. Hopefully this is a one-off and is not a widespread issue amongst users.
Not common at all, very likely it is a one-off with the charger. Glad you got it sorted with support and a replacement charger.
I have the same problem with my FW13 Pro Intel (X7 358H, 32 GB RAM, Prebuild). When the battery is almost fully charged (around 98 % - 99 %) and the charger is plugged in, the laptop will keep flipping between charging and discharging causing a beep every few seconds. I’m also running Ubuntu 24.04 which was preinstalled.
There are several threads of this topic, for example:
I use the framework charger for the EU which came with the laptop. On the charger it says “100W”. I have this problem since day 1. I wonder if this is an issue with the charger or if it affects everyone. If so, that would mean no one could use the device while it’s plugged in once the battery has reached a 100 % charge.
@FirstFrame What type of charger do you have?
I have the US Framework 100W charger.
I would definitely open a ticket with Framework support and see if you possibly have a faulty charger. After doing a bunch of tests with them, they finally sent me a new charger and I haven’t had the problem since.
