FW 16 stops responding, power button flashes and doesn't work
Framework 16, seems when it goes to sleep, sometimes it won’t wake up with movement, keyboard, or pressing the power button. The power button just flashes white slowly and I have to hold it down for 5+ seconds for it to shut off, then the power button works and it will turn on. I’ve looked at the event viewer and it’s not recognizing anything wrong, it just logs the manual shut down that I initiate.
I think it may be because of heat… is there no way to adjust the fans on this laptop?
