[FW13][W11] BSOD when IDLE a few minits and screen off
Hello community,
I am experiencing a highly specific and consistently reproducible BSOD on my new Framework Laptop 13 (AMD). I would appreciate any insight or assistance.
System Details:
  • Laptop: Framework Laptop 13
  • CPU: AMD AI 370
  • OS: Fresh installation of Windows 11 Pro
  • BIOS Version: 3.04
  • Drivers: The official Framework Driver Bundle for the AMD model, installed immediately after the OS. Also tried latest AMD drivers
Problem Description:
The system crashes with a DRIVER_POWER_STATE_FAILURE (9f) blue screen. This BSOD only occurs under the following very specific conditions:
  1. The laptop is left idle, running on AC power (dont tried with battery)
  2. The crash happens after several minutes that the screen powers off on IDLE status, also happens with music playing in background.
The crash does not occur if:
  • The laptop is being used actively.
Troubleshooting Steps Performed:
  1. Clean OS Install: The issue was present on a fresh installation of Windows 11.
  2. Official Drivers: The first thing I installed was the official Framework Driver Bundle. The issue persists.
  3. Memory Dump Analysis: I analyzed the full MEMORY.DMP file using WinDbg. The analysis points directly to a timeout in the DirectX Graphics Kernel Subsystem (dxgkrnl) during a power IRP request.
WinDbg Analysis Summary:
The !analyze -v output provided the following key information, clearly indicating a graphics driver power state issue:
*                        Bugcheck Analysis                                    *
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffd28e6ff11060, Physical Device Object of the stack
Arg3: ffffa30a794e79f0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffd28e76eb9790, The blocked IRP
Debugging Details:
Implicit thread is now ffffd28e`6b723080
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3656
    Key  : Analysis.Elapsed.mSec
    Value: 24264
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 44
    Key  : Analysis.Init.CPU.mSec
    Value: 1593
    Key  : Analysis.Init.Elapsed.mSec
    Value: 21022
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 136
    Key  : Analysis.Version.DbgEng
    Value: 10.0.27920.1001
    Key  : Analysis.Version.Description
    Value: 10.2506.23.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2506.23.1
    Key  : Bugcheck.Code.KiBugCheckData
    Value: 0x9f
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x9f
    Key  : Bugcheck.Code.TargetModel
    Value: 0x9f
    Key  : Dump.Attributes.AsUlong
    Value: 0x21800
    Key  : Dump.Attributes.DiagDataWrittenToHeader
    Value: 1
    Key  : Dump.Attributes.ErrorCode
    Value: 0x0
    Key  : Dump.Attributes.LastLine
    Value: Dump completed successfully.
    Key  : Dump.Attributes.ProgressPercentage
    Value: 100
    Key  : Failure.Bucket
    Value: 0x9F_3_DXG_POWER_IRP_TIMEOUT_IMAGE_ACPI.sys
    Key  : Failure.Hash
    Value: {647b8107-c400-6fbe-5ce8-dc5911f35388}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x6493cfd4
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 1
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38670575
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x24e10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : SecureKernel.HalpHvciEnabled
    Value: 1
    Key  : Stack.Pointer
    Value: NMI
    Key  : WER.OS.Branch
    Value: ge_release
    Key  : WER.OS.Version
    Value: 10.0.26100.1
    Key  : WER.System.BIOSRevision
    Value: 3.4.0.0
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffd28e6ff11060
BUGCHECK_P3: ffffa30a794e79f0
BUGCHECK_P4: ffffd28e76eb9790
FILE_IN_CAB:  MEMORY.DMP
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21800
FAULTING_THREAD:  ffffd28e6b723080
DRVPOWERSTATE_SUBCODE:  3
ADDITIONAL_DEBUG_TEXT:  DXG Power IRP timeout.
IRP_ADDRESS: ffffd28e76eb9790
DEVICE_OBJECT: ffffd28e6ff3cbd0
DRIVER_OBJECT: ffffd28e6b6aac90
IMAGE_NAME:  ACPI.sys
MODULE_NAME: ACPI
FAULTING_MODULE: fffff8070b340000 ACPI
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1 (!blackboxwinlogon)
PROCESS_NAME:  System
DPC_STACK_BASE:  FFFFA30A794E7FB0
STACK_TEXT:
ffffa30a`7941ef60 fffff807`78e566f0     : 00000000`00000047 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSwapContext+0x76
ffffa30a`7941f0a0 fffff807`78ece6cd     : ffffd28e`6b723080 ffffbd01`36000180 ffffa30a`7941f270 ffffd28e`6ff3cbd0 : nt!KiSwapThread+0x6b0
ffffa30a`7941f170 fffff807`78ecd34f     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiCommitThreadWait+0x39d
ffffa30a`7941f200 fffff807`0add3010     : ffffa30a`7941f318 ffffd28e`00000000 00000000`00000000 ffffd28e`81a51000 : nt!KeWaitForSingleObject+0x71f
ffffa30a`7941f2e0 fffff807`0add2d1c     : ffffa30a`7941f300 00000000`00000004 ffffb5a5`6af59298 00000000`00000000 : dxgkrnl!DpiFdoHandleDevicePower+0x2d0
ffffa30a`7941f370 fffff807`0adabc50     : ffffd28e`76eb9790 ffffd28e`76eb9790 ffffd28e`81a51180 ffffd28e`81a51030 : dxgkrnl!DpiFdoDispatchPower+0x1c
ffffa30a`7941f3a0 fffff807`78eedc6b     : ffffa30a`00000001 ffffd28e`81a51030 ffffd28e`81a51030 ffffbd01`00000000 : dxgkrnl!DpiDispatchPower+0xe0
ffffa30a`7941f4c0 fffff807`79081afa     : 00000000`00000000 ffffd28e`6b723080 fffff807`78eeda10 00000000`00000000 : nt!PopIrpWorker+0x25b
ffffa30a`7941f570 fffff807`7929ef84     : ffffbd01`361d3180 ffffd28e`6b723080 fffff807`79081aa0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
ffffa30a`7941f5c0 00000000`00000000     : ffffa30a`79420000 ffffa30a`79419000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
STACK_COMMAND: .process /r /p 0xffffd28e6b67a040; .thread 0xffffd28e6b723080 ; kb
FAILURE_BUCKET_ID:  0x9F_3_DXG_POWER_IRP_TIMEOUT_IMAGE_ACPI.sys
OS_VERSION:  10.0.26100.1
BUILDLAB_STR:  ge_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {647b8107-c400-6fbe-5ce8-dc5911f35388}
Followup:     MachineOwner
UPDATE1 (17/10/2025):
Ticket opened to FW support and bug report send to AMD using crash reporter.
UPDATE2 (20/10/2025):
Support answer very fast (during weekend) but maybe this issue in my case are fixed disabling “PCI Express” power saving under active power plan settings.
So far, I’ve been 3 days without any BSOD regarding this.
UPDATE3 (23/10/2025):
Still no BSOD on IDLE, only a few Windows freezes while playing Fornite with AMD Adrenalin v25.9.1.
UPDATE 3 (30/10/2025): BSOD is back.
Today, the issue occurred again after leaving the system IDLE with only one or two applications open and connected to a Lenovo ThinkPad Dock. This suggests that the problem may not be related to the power adapter being used.
I am hitting the same issue on latest Windows 11 with AMD AI 370, 64gb of ram, latest bios, hitting DRIVER_POWER_STATE_FAILURE (9F) through ACPI on the VGA device according to the debugger.
Thanks for the reply, we already talked this on my reddit post :slight_smile:
Please open a ticket so we can both try to send as much information as possible to the support team.
UPDATE 4 (09/11/2025): Is HWiNFO the culprit?
Last week I reinstalled Windows, and after installing applications one by one, I realized that HWiNFO might be the culprit, since I hadn’t installed it for the first few days to see if it was the source of the problem.
So, I haven’t had a single BSOD for a whole week now, whereas before it was happening almost daily.
I’ll post again in a few weeks.
Also having these issues, and had HWiNFO set to start on boot, disabling this now. Did you confirm that HWiNFO was the culprit in the end?
Hi mate.
Confirmed that HWInfo is the culprit. I disable to monitor all sensors except battery one, I use HWInfo just to monitor battery discharge rate and capacity in watts without any more BSODs.
So I think that the BSOD comes from monitoring some of the CPU ECs.
Try it and comment your result :slight_smile:
