Void
Which release version?
today (2026-09-16)
Which kernel are you using?
7.2.6_1
v4.05
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
7840hs with 7700s
Bought a “Lenovo ThinkPad Thunderbolt 5 Smart Dock 7500 40BA0265EU” docking station because it can deliver 180W over a single usb-c cable. I know that the 7840hs is usb4 and not tb5, but that shouldnt be an issue for usb-c power delivery as far as I understand.
Issue is, the dock randomly disconnects, but only under heavy power consumption. It’s stable on the desktop for hours without problems, but during gaming it will just randomly disconnect. Monitor is connected directly to the 7700s, not the dock. There are no issues when the Framework charger (180W) is connected as well, but that defeats the point of buying a 180W dock. kernel cmdlines pcie_acpm=off and pcie_port_pm=off have been tried unsuccesfully. USB-Autosuspend for the dock has been disabled in tlp.
dmesg logs during disconnection (dmesg before, dmesg after, then diff):
[ 184.765143] thunderbolt 0-0:2.1: retimer disconnected
[ 184.766062] thunderbolt 0-2: device disconnected
[ 184.792866] usb 5-1.2: USB disconnect, device number 3
[ 184.792966] usb 5-1.2.3: USB disconnect, device number 7
[ 184.793040] usb 5-1.2.3.2: USB disconnect, device number 8
[ 184.824561] usb 6-1: USB disconnect, device number 2
[ 184.824721] usb 6-1.4: USB disconnect, device number 3
[ 184.824799] usb 6-1.4.3: USB disconnect, device number 4
[ 184.876805] r8152-cfgselector 6-1.4.4: USB disconnect, device number 5
[ 184.907553] usb 5-1: USB disconnect, device number 2
[ 184.908639] usb 5-1.3: Unable to submit urb #1: -19 at snd_usb_queue_pending_output_urbs
[ 184.912370] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.917720] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.922954] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.928257] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.933466] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.938979] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.944250] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.949781] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.954951] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.959424] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.964755] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.970091] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.975450] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.980743] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.986070] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.991426] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 184.996762] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.002084] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.007432] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.012740] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.018069] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.023494] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.028759] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.034090] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.039400] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.044734] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.050071] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.055460] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.060776] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.066102] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.071414] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.076730] usb 5-1.3: cannot submit urb 0, error -19: no device
[ 185.078894] usb 5-1.3: USB disconnect, device number 4
[ 185.110606] usb 5-1.4: USB disconnect, device number 5
[ 186.188035] ucsi_acpi USBC000:00: unknown error 256
[ 186.781431] usb 5-1: new high-speed USB device number 9 using xhci_hcd
[ 186.891912] thunderbolt 0-2: new device found, vendor=0x108 device=0x234d
[ 186.891917] thunderbolt 0-2: Lenovo ThinkPad Thunderbolt 5 Smart Dock 7500 - 40BA
[ 186.908740] usb 5-1: New USB device found, idVendor=17ef, idProduct=3114, bcdDevice= 1.01
[ 186.910578] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 186.910586] usb 5-1: Product: Lenovo Dock - USB2.0 Hub
[ 186.910592] usb 5-1: Manufacturer: Lenovo
[ 186.992516] hub 5-1:1.0: USB hub found
[ 186.993115] hub 5-1:1.0: 5 ports detected
[ 187.121775] thunderbolt 0-0:2.1: new retimer found, vendor=0x7fea device=0x1032
[ 187.592839] usb 5-1.2: new high-speed USB device number 10 using xhci_hcd
[ 187.689653] usb 5-1.2: New USB device found, idVendor=17ef, idProduct=3111, bcdDevice=50.33
[ 187.700828] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 187.700938] usb 5-1.2: Product: Lenovo Dock - USB2 Hub1
[ 187.701011] usb 5-1.2: Manufacturer: Lenovo
[ 187.754303] hub 5-1.2:1.0: USB hub found
[ 187.755522] hub 5-1.2:1.0: 4 ports detected
[ 187.896373] usb 6-1: new SuperSpeed Plus Gen 2x1 USB device number 6 using xhci_hcd
[ 187.909401] usb 6-1: New USB device found, idVendor=8087, idProduct=5787, bcdDevice= 0.00
[ 187.911494] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 187.911594] usb 6-1: Product: USB3 HUB
[ 187.911671] usb 6-1: Manufacturer: Intel Corporation
[ 187.986779] usb 5-1.3: new full-speed USB device number 11 using xhci_hcd
[ 188.085039] usb 5-1.3: New USB device found, idVendor=17ef, idProduct=3115, bcdDevice= 0.51
[ 188.116078] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 188.116185] usb 5-1.3: Product: Lenovo Dock - USB Audio
[ 188.116255] usb 5-1.3: Manufacturer: Lenovo
[ 188.116324] usb 5-1.3: SerialNumber: 000000000000
[ 188.446561] hub 6-1:1.0: USB hub found
[ 188.446646] hub 6-1:1.0: 4 ports detected
[ 188.490049] input: Lenovo Lenovo Dock - USB Audio Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c7:00.3/usb5/5-1/5-1.3/5-1.3:1.3/0003:17EF:3115.0014/input/input42
[ 188.541037] input: Lenovo Lenovo Dock - USB Audio as /devices/pci0000:00/0000:00:08.3/0000:c7:00.3/usb5/5-1/5-1.3/5-1.3:1.3/0003:17EF:3115.0014/input/input43
[ 188.541304] hid-generic 0003:17EF:3115.0014: input,hiddev3,hidraw4: USB HID v1.11 Device [Lenovo Lenovo Dock - USB Audio] on usb-0000:c7:00.3-1.3/input3
[ 189.033436] usb 5-1.4: new full-speed USB device number 13 using xhci_hcd
[ 189.131752] usb 5-1.4: New USB device found, idVendor=17ef, idProduct=310d, bcdDevice=12.06
[ 189.149163] usb 5-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 189.149171] usb 5-1.4: Product: Lenovo ThinkPad Thunderbolt 5 Smart Dock 7500 - 40BA DMC
[ 189.149174] usb 5-1.4: Manufacturer: Lenovo
[ 189.149177] usb 5-1.4: SerialNumber: 1S40BAZEBA000E
[ 189.216168] usb 6-1.4: new SuperSpeed Plus Gen 2x1 USB device number 7 using xhci_hcd
[ 189.225909] usbhid 5-1.4:1.2: couldn't find an input interrupt endpoint
[ 189.229590] usb 6-1.4: New USB device found, idVendor=17ef, idProduct=3110, bcdDevice=50.33
[ 189.233020] usb 6-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 189.233027] usb 6-1.4: Product: Lenovo Dock - USB3 Hub1
[ 189.233030] usb 6-1.4: Manufacturer: Lenovo
[ 189.233900] hid-generic 0003:17EF:310D.0015: hiddev4,hidraw5: USB HID v1.11 Device [Lenovo Lenovo ThinkPad Thunderbolt 5 Smart Dock 7500 - 40BA DMC] on usb-0000:c7:00.3-1.4/input3
[ 189.264194] hub 6-1.4:1.0: USB hub found
[ 189.264830] hub 6-1.4:1.0: 4 ports detected
[ 189.304439] usb 5-1.2.3: new high-speed USB device number 14 using xhci_hcd
[ 189.397315] usb 5-1.2.3: New USB device found, idVendor=17ef, idProduct=3113, bcdDevice=50.73
[ 189.404060] usb 5-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 189.404066] usb 5-1.2.3: Product: Lenovo Dock - USB2 Hub2
[ 189.404069] usb 5-1.2.3: Manufacturer: Lenovo
[ 189.440123] hub 5-1.2.3:1.0: USB hub found
[ 189.441437] hub 5-1.2.3:1.0: 4 ports detected
[ 189.824042] usb 6-1.4.3: new SuperSpeed Plus Gen 2x1 USB device number 8 using xhci_hcd
[ 189.840169] usb 6-1.4.3: New USB device found, idVendor=17ef, idProduct=3112, bcdDevice=50.73
[ 189.843825] usb 6-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 189.843829] usb 6-1.4.3: Product: Lenovo Dock - USB3 Hub2
[ 189.843832] usb 6-1.4.3: Manufacturer: Lenovo
[ 189.920800] hub 6-1.4.3:1.0: USB hub found
[ 189.921524] hub 6-1.4.3:1.0: 4 ports detected
[ 190.047802] usb 6-1.4.4: new SuperSpeed USB device number 9 using xhci_hcd
[ 190.059631] usb 6-1.4.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=31.21
[ 190.059789] usb 6-1.4.4: Int endpoint with wBytesPerInterval of 8 in config 2 interface 0 altsetting 0 ep 0x83: setting to 16
[ 190.059863] usb 6-1.4.4: Int endpoint with wBytesPerInterval of 8 in config 3 interface 0 altsetting 0 ep 0x83: setting to 16
[ 190.060099] usb 6-1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 190.060102] usb 6-1.4.4: Product: USB 10/100/1G/2.5G LAN
[ 190.060105] usb 6-1.4.4: Manufacturer: Realtek
[ 190.060108] usb 6-1.4.4: SerialNumber: 121301A568
[ 190.155598] usb 5-1.2.3.2: new full-speed USB device number 15 using xhci_hcd
[ 190.335757] usb 5-1.2.3.2: New USB device found, idVendor=046d, idProduct=c335, bcdDevice= 6.02
[ 190.352678] usb 5-1.2.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 190.352684] usb 5-1.2.3.2: Product: Gaming Keyboard G910
[ 190.352685] usb 5-1.2.3.2: Manufacturer: Logitech
[ 190.352687] usb 5-1.2.3.2: SerialNumber: 1975307B3033
[ 190.399816] r8152-cfgselector 6-1.4.4: reset SuperSpeed USB device number 9 using xhci_hcd
[ 190.534975] input: Logitech Gaming Keyboard G910 as /devices/pci0000:00/0000:00:08.3/0000:c7:00.3/usb5/5-1/5-1.2/5-1.2.3/5-1.2.3.2/5-1.2.3.2:1.0/0003:046D:C335.0016/input/input44
[ 190.614594] hid-generic 0003:046D:C335.0016: input,hidraw19: USB HID v1.11 Keyboard [Logitech Gaming Keyboard G910] on usb-0000:c7:00.3-1.2.3.2/input0
[ 190.622538] input: Logitech Gaming Keyboard G910 Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c7:00.3/usb5/5-1/5-1.2/5-1.2.3/5-1.2.3.2/5-1.2.3.2:1.1/0003:046D:C335.0017/input/input45
[ 190.673652] hid-generic 0003:046D:C335.0017: input,hiddev9,hidraw20: USB HID v1.11 Keyboard [Logitech Gaming Keyboard G910] on usb-0000:c7:00.3-1.2.3.2/input1
[ 191.766233] elogind-daemon[2276]: Watching system buttons on /dev/input/event17 (Logitech Gaming Keyboard G910 Keyboard)
[ 191.766363] elogind-daemon[2276]: Watching system buttons on /dev/input/event16 (Logitech Gaming Keyboard G910)
[ 194.370265] r8152 6-1.4.4:1.0 eth0: carrier on
I’ve also tried all four usb-c ports on the laptop and disconnected the dock from the laptop and its power brick for about ten minutes. Dock firmware is up-to-date according to fwupd (I installed an update right after unpacking the dock).
I found a post by someone here who had similar issues with this dock, he solved it by disabling mux in the amd driver settings. I don’t have access to anything like that on linux.
I would assume that it’s power draw related, but I don’t know how to fix this.
