FW16 JFAN Connector Part Number
Does anyone know what the part number for the fan connectors on the 5070 GPU are or where they might be found?
Don’t know that those would be published anywhere readily. Might try looking at parts from Digikey or Mouser to find a few brands that make that style. Then the manufacturer might have a catalog of the connectors that are made.
Though spendy, replacement fans can be purchased but that only gives one half and not the one that is connected to the expansion card.
i think if you google framework laptop schematic git. you can find official github of framework and the various models in there. but just then, i click it, it 404. so im not sure what’s goin on. :sweat_smile:
i already got my copy of fw desktop schema in my local drive from their git.
Here it is on our Github: ExpansionBay/PCB Reference Design/FW_EXPANSION_BAY_PCB_0807.pdf at main · FrameworkComputer/ExpansionBay · GitHub
Whats the url you’re using? should be this one: Framework · GitHub
