Glue specification spacers/touchpad
I want to try to retrofit a full width frame for the touchpad. My plan is to take the standard Framework parts, and reuse everything except the sheetmetal.
It would be helpful to know what glue is used (I am assuming it is glued) to attach the plastic parts to the sheetmetal? That way I can hopefully come up with a reliable way of removing the sheetmetal without damaging other parts.
I don’t know what glue is used.
I am curious as to how you attach the plastic parts so accurately.
I think the tolerances are very low.
