Hi. I received my i7-1165 DIY unit with BIOS 03.07 yesterday and did a fresh installation of POP!_OS 22.04 LTS which uses kernel 5.16.19 and my two network dongles with the ASIX AX88179 chipset don’t get link. A Realtek chip based adapter does work. I get the same results booting Ubuntu 20.04 LTS with kernel 5.13.0-40 from usb on the FW. The two usb-a adapters worked out of the box with the same POP!_OS and Ubuntu images booting from usb on my 2012 MacBook Pro.
Update: The ASIX usb-a adapter worked on my mips based router running OpenWrt as well. It is looking like the frame.work computer may be the issue but what specifically and why?
Here is some data I collected:
output of a few commands and dmesg excerpts
sm@pop-os:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 12:b8:4f:xx:xx:xx brd ff:ff:ff:ff:ff:ff permaddr 82:09:f3:xx:xx:xx
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 26:e4:4c:xx:xx:xx brd ff:ff:ff:ff:ff:ff permaddr 92:bb:3a:xx:xx:xx
4: wlp170s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether bc:09:1b:xx:xx:xx brd ff:ff:ff:ff:ff:ff
sm@pop-os:~$ sm@pop-os:~$ lsusb
Bus 003 Device 003: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
Bus 003 Device 002: ID 0bda:5634 Realtek Semiconductor Corp. Laptop Camera
Bus 003 Device 004: ID 8087:0032 Intel Corp. AX210 Bluetooth
Bus 002 Device 002: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
sm@pop-os:~$ lshw
*-network:0
description: Ethernet interface
physical id: b
bus info: usb@2:1
logical name: eth0
serial: 12:b8:4f:xx:xx:xx
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=off broadcast=yes driver=ax88179_178a driverversion=5.16.19-76051619-generic duplex=half link=no multicast=yes port=MII speed=10Mbit/s
*-network:1
physical id: c
bus info: usb@2:1
logical name: eth1
serial: 26:e4:4c:xx:xx:xx
capacity: 1Gbit/s
sm@pop-os:~$ sudo dmesg
[ 0.000000] microcode: microcode updated early to revision 0x88, date = 2021-03-31
[ 0.000000] Linux version 5.16.19-76051619-generic (jenkins@warp.pop-os.org) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #202204081339~1649696161~22.04~091f44b SMP PREEMPT Mon Apr 11 17
[ 0.000000] DMI: Framework Laptop/FRANBMCP0B, BIOS 03.07 12/14/2021
[ 2.206285] usb 2-1: New USB device found, idVendor=0b95, idProduct=1790, bcdDevice= 2.00
[ 2.206288] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.206289] usb 2-1: Product: AX88179A
[ 2.206291] usb 2-1: Manufacturer: ASIX
[ 2.206291] usb 2-1: SerialNumber: 008F857D
[ 2.315043] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 2.322188] usb 3-10: new full-speed USB device number 4 using xhci_hcd
[ 2.326797] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 2.473207] usb 3-10: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00
[ 2.473216] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.541730] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.652419] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 2.652429] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): invalid MAC address, using random
[ 2.662864] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0006: -32
[ 2.673293] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 2.683491] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.695504] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.705901] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.716408] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.726919] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 2.737211] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.748917] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 2.759271] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 2.769972] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 2.780328] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 2.790883] ax88179_178a 2-1:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 2.898279] ax88179_178a 2-1:2.0 eth0: register 'ax88179_178a' at usb-0000:00:0d.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 82:09:f3:ba:8d:5d
[ 3.040988] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 3.051394] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 3.265964] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 3.376867] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 3.376878] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): invalid MAC address, using random
[ 3.387212] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0006: -32
[ 3.397538] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 3.611328] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 3.623288] ax88179_178a 2-1:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 3.623595] ax88179_178a 2-1:2.1 eth1: register 'ax88179_178a' at usb-0000:00:0d.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 92:bb:3a:bd:b2:26
[ 3.668294] usbcore: registered new interface driver ax88179_178a
[ 3.670978] usbcore: registered new interface driver cdc_ether
[ 3.672423] usbcore: registered new interface driver cdc_ncm
[ 3.726579] system76_acpi: loading out-of-tree module taints kernel.
[ 3.726591] system76_acpi: module verification failed: signature and/or required key missing - tainting kernel
[ 3.728056] system76: Model does not utilize this driver
[ 3.793786] usbcore: registered new interface driver system76-io
[ 19.133752] ax88179_178a 2-1:2.1 eth1: Failed to read reg index 0x0000: -71
[ 19.140752] ax88179_178a 2-1:2.1 eth1: Failed to read reg index 0x0001: -71
[ 19.147751] ax88179_178a 2-1:2.1 eth1: Failed to read reg index 0x0009: -71
[ 19.154749] ax88179_178a 2-1:2.1 eth1: Failed to read reg index 0x000a: -71
[ 19.161760] ax88179_178a 2-1:2.1 eth1: Failed to read reg index 0x0004: -71
Any ideas for what is wrong or what to look at or try to get it working?
Thanks in advance.
