Hello,
I am coming from Mac and I loved the option to reduce even more the brightness and be able completely turn off the screen (no brightness at all).
I would like to do the same on Windows 11 and ideally adjust the value of the brightness selector (100: maximum brightness and 0: screen is off).
It seems that the limitation of the minimum brightness is not linked to Windows 11 as some PC.
I already check and find nothing that fit my needs. If you have any clue that would be perfect ![]()
Thanks
