I had some issues with my AI 9 mainboard - fixes
I’m not using my mainboard in a conventional way. I have 3d printed a cyberdeck case for it, and was enjoying it for the most part, but there were a couple of issues I had right off the bat that ended up being related, but I had no idea!
The first problem I had is I would get a TON of audio interference when plugged into speakers or headphones. I tried to fix it with easy effects, only to find out it wasn’t a problem with the OS audio output, it was a problem with the audio hardware producing dirty signals due to power interference. I thought this was just because of the fact that in my case the battery is mounted directly under the main board and didn’t worry about it.
The other issue I had was with thermals. This thing would run very hot even when not under heavy load. My case design has plenty of ventilation above the cooler fan, but I thought maybe because the fan typically pulls air from the bottom that it wasn’t pulling enough air from the top. This is what led me to see if I could remove the fan and mount it upside down. This wasn’t possible, but it was what revealed the issue for both my thermal problem and my audio noise problem.
When I tried to plug the fan back into the motherboard it wouldn’t go. It just felt like something was in the way. I took the main board out of the case and shined a light into the fan connector, and sure enough the left most pin was horribly bent! I straightened that pin out with some very small tweezers (it was a massive pain to do) and sure enough the fan plug slotted in with no problems. Now my audio is clean and my thermals are way better!
My theory is that the pin was bent from the factory and not making good contact with the connector, so while the fan was running it was running in a very un-ideal way. leading to it generating a ton of electrical noise and probably heating the fan motor up too much to properly cool the APU.
So if you’re getting almost staticy or pulsey audio interference on your speakers or headphones, check to see if that left most pin in the CPU fan connector is bent!
Note to the framework team:
this board is a beast, it lives up to expectation now that the cooling is working properly, but you may want to adapt your manufacturing/QA process to plug the fan connector in, then unplug it and make sure that left pin isn’t bent. There maybe a problem with the fan connection process at the factory that bends this pin sometimes.
