I Need Help! I purchased a new AMD Ryzen 5 DIY version and turned it on and says Default Boot Device missing or boot failed
PLEASE READ BEFORE POSTING:
Are you looking into the forum because you’re having potential issues with your Framework laptop? Before creating a post, we may have a guide, FAQ, or thread that can hopefully help!
In the body of your post, please include those following details.
  • Which OS (Operating System)? None yet but want to install windows 11
  • Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory)
  • Which Framework laptop (11th, 12th or 13th generation Framework laptop, 13th gen with AMD Ryzen 5 Chromebook or Framework Laptop 16) are you asking for support with?
  • If there is no information pertaining to your issue or question, please let us know here: Framework | Support Framework | Fix Consumer Electronics
You need to install the OS on the SSD yourself. You can find the appropriate guides here: Framework Laptop 13 - Framework Guides
The DIY edition requires that you install an operating system. There are preliminary steps you must take before you “turn it on”. Since you have indicated that you wish to install Windows, you should follow the instructions in this guide.
Dino
@Monique_DiVarco
If the install guide linked to on the comment above does not help you.
Are you able to provide any more details regarding what you have purchased?
It is possible to purchase a FW laptop without any storage.
So, if you could tell us the parts you have purchased we might be able to help further.
You have told us you have a Framework Laptop 13.
How much RAM does it have?
Which NVME SSD do you have with it?
Which expansion slot cards did you purchase?
