I Need Mainboard Screws. How can I get them?
A few weeks back, I ordered a Laptop 13 (chassis only), a RISC-V mainboard. More recently, I got an AMD mainboard.
Everything has been great, except that none of these shipments included screws for mounting the mainboards within the chassis!
Does anyone know the specs for these screws? Even more importantly, where could I buy them?
Does this help?
Yes! I looked for something like this in the store, but must have overlooked it. Thanks!
Welcome to the community @Peter_Webb !
Pro Tip for others ordering parts or accessories (expansion cards, upgrades etc.) buy a pack of the mainboard and chassis screw packs (yes they are two separate packs). They are only a few dollars and will be invaluable if a screw is misplaced, or breaks off, or disappears mysteriously when you swore you had them all set aside! Many of these are not available locally.
I think the chassis should’ve included the screws but there were some other reports that their screws were missing, too. So I would message support if they could send you the screws for free.
