I think my framework died
I’ve already contacted support about this, and I’m going to have to wait and see what they say this is only my second day having my framework, but I had just started my framework up and was watching some YouTube videos when all of a sudden it made a pop. The screen went dead, and the whole laptop turned off. I unplugged everything, and as I was doing that, I could smell burning. I waited just a little bit and opened it up, and it doesn’t look like there’s anything burnt or messed up.
If you heard a pop, and it is not responding to the power button now, then my question would be:
Do you see any charging LEDs when you plug power into it?
If you don’t, then I think the issue is with the BMS and power rails. Most likely will be a RMA warranty replacement.
I plugged it in and there’s no charging light.
