I am able to start the laptop with no problems.
When I put the machine to sleep myself I do not get the following behaviour.
However, if I set away from the machine and leave it to go into sleep mode as per the power settings it will enter sleep but after a period of being asleep (5-10mins I haven’t timed it but its not longer than that) I get a BIOS type screen with a blue box in the middle with the message “default boot device missing or boot failed” etc.
I only get this message after the machine puts itself to sleep. No other time.
It boots up and runs as expected. When I get the message I simply reboot the machine as per normal. I do not have to do anything like select the boot device.
Aside from this I do not have any issues with the laptop. (Except for fan noise when playing games - I figuring that is normal - I’ve migrated from a MacBook so not used to fan forced cooling)
I have checked under BIOS and the SSD is listed as 1st boot device.
Anyone got any ideas about this behaviour?
