So this bottom right captive screw (as seen from keyboard) never fully comes loose after unscrewing like the others do. I’m looking the screw from the inside and it looks a little different than the others. Is this screw correct? I get why it clicks, it’s just the screw pushing against the threading, clicking every full turn. What do you guys think? Is yours the same?
A post was merged into an existing topic: SOLVED Input cover wont go on properly on front right side
