My laptop has one screw that does not come out and snaps down whenever I try to take it out. I don’t want to damage this laptop. Edit: I found out that it is designed that way
Sounds like you’ve forced the other screws out? (The extent of ‘out’ needs clarity here)
I think I have the same issue as OP. If so, they’re talking about it not “come loose”, none of them come out entirely of course, that would be bad. But I also have an issue with this exact screw that it doesn’t “rise up” nicely when you unscrew it.
I ended up having to lift the keyboard panel from the other corner and wiggle it basically.
