The Intel driver assistant is warning me that OEM customizations will be overwritten. Is it safe to continue with this graphics driver update?
My framework is a gen 12.
Thanks.
Thanks.
This question was asked for the 11th Gen models also.
The answer was that Frame.work did not customize the drivers.
So go for it.
However, if it’s offering to install Arc support, don’t bother, because that doesn’t help you.
