I think it was just something maybe a bit more blunt, or heavy in my bag, or setting down on my laptop (like a book maybe I dropped on it or something). I’m not 100% sure what did it, only that I didn’t expect it to be broken because I didn’t do anything to it that I feel would have been extreme.
Ordering was super easy,
Was surely not under warrenty because it wasnt a defect necisarily.
It was very very easy to replace the screen, 4 screws and a cable. Took longer to look at the instructions to replace it than it did to replace it. The 2nd time took about 3 minutes to replace.
That is pretty funny! Thank you for your testimony. It really helps to make it more concrete the relatively good experience most customers are having with Framework. I think it adds value to the laptop and make people like me less inclined to think it is an “expensive machine”.
I have here a pretty good Dell Laptop with the screen badly cracked (but still working); I slipped in a rainy day and fell quite hard over my backpack with my whole weight (100Kg/220lb). Took me a really long time (and trouble) to track down a replacement screen, and when I found it the cost was astonishingly prohibitive, so I kept using it (for a time) with the screen cracked, but mostly connected to external monitors. From that point on, I’ve been pretty adamant on using an EVA-formed case protector every time my laptop enters my backpack.
It is not exactly cheap, but I think it is a well worth investment. 3 years using it, couldn’t possibly be more satisfied, I recommend it to everyone. Very sturdy, durable, incredible zipper.
1280p is an exceedingly poor value, and will likely be throttled by heat/TDP, I imagine.
I chose 1260p for the extra cache and EUs, but at 300 extra it’s arguably a very wasteful choice.
12th gen is like 40% faster and should be more power efficient, it’d be foolish to go with 11th gen unless you already own one.
Initially, I thought that I did not need to upgrade to 12th gen–the 11th gen did everything that I wanted.
Then I started playing some games again, and the thermal throttling was unbearable.
To this community, I’m sure the pain is imaginable when you see the Iris Xe perfectly capable of playing a game at full resolution, then taking a nosedive moments later.
The Iris Xe didn’t see any architectural improvements this iteration, but maybe the node shrink will help.
Short of attaching a blower fan to a duct under the laptop, or buying an eGPU, there are few solutions
There is a lot of room for improvement apparentely kernel wise. Linux kernel 5.19 seems to lower a lot power drawn in many scenarios including cinebench stuf( it s20% i think)
