Hi,
I’m on a FW13 with the latest BIOS / Drivers ( Framework Laptop BIOS and Driver Releases (11th Gen Intel® Core™))
I purchased a [larger] replacement battery, and ever since – doubt it’s related, but the timing is truly impeccable – have severe graphics glitches, which almost entirely occur when using split screen in windows.
- I tried reseating the display cable.
- If/When they happen in split screen, switching to full almost always fixes it. (The attached picture is an exception.)
- Sometimes the entire screen turns static-glitchy.
- Because it was limited almost 99% to split screen, I updated the bios and drivers, but it keeps happening.
- I plugged in an external monitor, the glitches only happen on the laptop.
- If it posts, here’s a link of a short video showing some of the glitches: sad framework (youtube.com)
Time to buy a new mainboard/gpu? Maybe I somehow installed drivers incorrectly? I can’t see how I knocked loose anything when installing the new battery, and the display connection looks fine to my eye.
Thanks.
p.s. It’s been a run of bad luck with this laptop and display artifacts, a new one would be my third, so maybe it’s been the mainboard/gpu the entire time. What do I know?
