Laptop will not turn on... again
This is the second time ive had an issue where my laptop would not turn on.
I am recieving a LED output sequence (attached to twitter post below)
I believe it to be:
----- main disgnosis sequence
12 green
------ post section
6 blue 2 green
I am not rough with my laptop and the only movement it experiences is being carried in my tote/messenger bag to work.
Last time I had an issue it was related to the battery I believe because once i reconnected the battery the laptop started up again… I tried that again this time… Hopefully I have not damaged the battery connection pins. I need a magnifying glass to look closer at this.
I really want to recommend the framework laptop to friends, but so far small hardware issues and large ones (like this) have slowed my initial enthusiasm. I feel like Im being punished for being an early adopter. Also when I have reached out to framework support before they were not super helpful. Suggesting things I had already accounted for and directing me to the LED output sequence documentation rather than assisting in diagnosis or discussing how this could have happened. I really want to love Framework and hope my experience will improve.
now it appears pin 9 and/or 10 may be bent on the power socket on the mainboard
Seems like this might be related to this post:
I’m not sure it will be as simple as a battery replacement because the pins bent are on the board not the battery…
I have reached out to support, and am still waiting on a response from them.
Yea I mean I would have never touched it if my laptop didn’t randomly stop working. Now I feel like I’ve made it even worse.
I think that the absolute simplest fix for this would be to swap the connector plugs, so the female end is on the motherboard, so if you bend a pin it’s on the battery, which is cheaper than a motherboard. :stuck_out_tongue:
Exposing metal attached to a power source is a bad idea. That’s why wall sockets are female…
Username doesn’t check out.
The solution can’t be to replace the >$1000 motherboard… For a bent pin… I imagine that someone with the right tools should be able to bend the pin back, or de-solder the socket and fix it with a replacement…I’m no an electronics-engineer, but it should be accomplish-able. Seems like it should be significantly cheaper than replacing an entire mainboard (talk about e-waste)
Correct. It’s referred to as component-level repair. Rossmann Repair Group could potentially fix this with ease.
What I mean is that the thin-pins idea isn’t the best one. Take a look at this paint sketch. (Pins are on the battery, but shielded.
Also, exactly like molex connectors (on the left):
Molex on the PSU side is female. Power source is always female.
PC Power Supply Voltage Data and Connector Types - Free Knowledge Base- The DUCK Project: information for everyone (robotz.com)
The image in your post, that’s the molex connector on the load side.
Easy fix man, probably would cost 2 cents for the part.
