Laptop will not turn on anymore
In the body of your post, please include those following details.
  • Which OS (Operating System)?
    endeavour OS
  • Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory)
    Issue is not OS Related and i cant remember what it is
  • Which Framework laptop
    11th generation or 12th
Im in a lecture right now so i dont have much time. sry for the brevity
my laptop started to only boot with AC power connected. now a day later it wont start at all. there are no indicator lights on anywhere
If this is an 11th gen board, there’s a good chance that the RTC battery needs to be replaced. Support will send you one for free. Make sure to use that one or if you source one on your own, make sure that it is rechargeable. Also, follow the directions very carefully, as the RTC battery holder is extremely fragile. Best of luck.
I think ibkNhubert got it right, I’m just including a link to a much more detailed post I’ve made about this issue: Laptop won't power on unless i plug in AC power - #216 by Tom1
