I bought a framework a little while back and have consistently had trouble with the wifi card. My setup is Manjaro Linux with XMonad as DE. The problem I have is:
- Bootup, connect to wifi
- Browser for a while, sometimes minutes, sometimes hours
- Wifi will be connected, but internet cuts out. Webpages wonβt load and simple things like
ping google.comalso fail on DNS resolution. - I checked
journalctl --bootsince this just happened and donβt see anything relevant - To fix, I can manually turn wifi on/off or I run
systemctl restart NetworkManager. This usually fixes it, but then the issue will come back at some random time later.
I would love to get to the root of this and fix it, any suggestions on what to look for or just fixes?
Hardware: Framework DIY Edition, Intel Wi-Fi 6E AX210 No vPro
β― neofetch
ββββββββββββββββββ ββββββββ entilzha@minbar
ββββββββββββββββββ ββββββββ ---------------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: Laptop AB
ββββββββ ββββββββ Kernel: 5.13.19-2-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 11 hours, 8 mins
ββββββββ ββββββββ ββββββββ Packages: 1714 (pacman)
ββββββββ ββββββββ ββββββββ Shell: fish 3.4.1
ββββββββ ββββββββ ββββββββ Resolution: 2256x1504
ββββββββ ββββββββ ββββββββ DE: xmonad
ββββββββ ββββββββ ββββββββ WM: LG3D
ββββββββ ββββββββ ββββββββ Theme: Adwaita [GTK2], Adw-dark [GTK3]
ββββββββ ββββββββ ββββββββ Icons: Adwaita [GTK2], Papirus-Dark [GTK3]
ββββββββ ββββββββ ββββββββ Terminal: kitty
CPU: 11th Gen Intel i7-1165G7 (8) @ 4.700GHz
GPU: Intel TigerLake-LP GT2 [Iris Xe Graphics]
Memory: 3672MiB / 15790MiB
