Can the mainboard for the current gen be made available at the same time or soon after each new laptop, rather than needing to wait for the next gen laptop to release the previous gen as a mainboard?
Using the generic Cooler Master case and a portable screen this provides an alternative to the laptop form factor. I currently carry a laptop + keyboard + portable screen, but would prefer to carry a standalone mainboard + keyboard + portable screen. Decoupling from the laptop form factor could also enable other mainboard designs where there are eg. multiple CPU slots.
Latest-gen mainboards are made available shortly after the release of new generation laptops. It takes a week or two, less than a month, but they do appear shortly after. You don’t have to wait until the next generation.
Old gen mainboards go on sale to move them, and two-generation-behind mainboards get discounted even further.
Thanks yes I see the Core Ultra Series 1 and AMD 7040 mainboards. Are the Cooler Master kits compatible with all gens then? So can I buy the Cooler Master kit that is listed for the 13th Gen Intel Core, without a mainboard, and slot in a Core Ultra Series 1 mainboard?
Hey is the Cooler master kit compatible with the Ryzen AMD 7040 series mainboard as there is no kit listed in the marketplace compatible with the cooler master but I don’t see any reason why it wouldn’t be compatible, I’m aware it needs also the RTC battery I believe as it is not on the motherboard of the laptop.
In addition to the RTC, you need to make some BIOS changes for it to run in the Coolermaster case. I needed to stick the mainboard in a 13" with screen and keyboard to make the changes, then put it in the coolermaster.
I’ve heard that there are ways of getting around this, but none of them worked for me.
