Networking fails and long boot times after waking from sleep with 6.19.x (AI 7 350), perfectly okay with 6.18.13
  • Fedora 42 KDE Plasma
Which kernel are you using?
  • 6.19.x causes issues.
  • Currently running 6.18.13. No problems.
  • 3.05
  • Ryzen 7 AI 350
After updating kernel to 6.19.x, my machine started to take ~10 seconds to wake from sleep and would lose network functionality. No WiFi, no BT.
At the time, I had an AX200 as my network card. I replaced the AX200 with an AX210 hoping that would fix things. Unfortunately, when running a new kernel and an AX210, the screen would never display anything no matter how long I waited after opening the lid.
A warm boot (restart/reboot) did not restore network functionality, only cold boots from shutdown would bring WiFi back.
I have unsuccessfully tried:
  • modprobe iwlwifi and modprobe -r, does nothing
  • systemctl restart NetworkManager, does nothing
  • tried disabling WiFi powersaving via /etc/modprobe.d/iwlwifi.conf, does nothing useful
  • appending pcie_aspm=off, pcie_port_pm=off, mem_sleep_default=deep, iwlwifi.power_save=0, and iwlwifi.d0i3_disable=1 to GRUB_CMDLINE_LINUX in /etc/default/grub, didn’t help, reverted
I’ve since re-downloaded 6.18.13 and it has behaved exactly as it should with both the AX200 and AX210. (Open lid, log in, wait a second or two for WiFi to reconnect, done.) I understand holding on an old kernel in Fedora isn’t best practice, but it’s the only way I can keep using my 13 daily for now.
Logs below:
Mar 16 13:12:47 fw-13 NetworkManager[1318]: [1773619967.6284] agent-manager: agent[75c05075d806819c,:1.86/org.kde.plasma.networkmanagement/1000]: agent registered
Mar 16 13:12:48 fw-13 NetworkManager[1318]: [1773619968.2566] audit: op=“statistics” interface=“wlp192s0” ifindex=2 args=“500” pid=3312 uid=1000 result=“success”
Mar 16 13:13:10 fw-13 NetworkManager[1318]: [1773619990.8600] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 16 13:13:10 fw-13 NetworkManager[1318]: [1773619990.8604] device (wlp192s0): state change: unavailable → unmanaged (reason ‘unmanaged-sleeping’, managed-type: ‘full’)
Mar 16 13:13:10 fw-13 NetworkManager[1318]: [1773619990.8921] manager: NetworkManager state is now ASLEEP
Mar 16 13:16:27 fw-13 NetworkManager[1318]: [1773620187.6874] manager: sleep: wake requested (sleeping: yes enabled: yes)
Mar 16 13:16:27 fw-13 NetworkManager[1318]: [1773620187.6878] device (wlp192s0): state change: unmanaged → unavailable (reason ‘managed’, managed-type: ‘external’)
Mar 16 13:16:27 fw-13 NetworkManager[1318]: [1773620187.6885] platform-linux: do-change-link[2]: failure 1 (Operation not permitted)
Mar 16 13:16:27 fw-13 NetworkManager[1318]: [1773620187.6891] manager: NetworkManager state is now CONNECTED_LOCAL
[OZH@fw-13]~% lspci | grep -i network
c0:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
[OZH@fw-13]~% echo 1 | sudo tee /sys/bus/pci/devices/0000:c0:00.0/reset
1
tee: ‘/sys/bus/pci/devices/0000:c0:00.0/reset’: Inappropriate ioctl for device
[OZH@fw-13]~%
[OZH@fw-13]~% uname -r
6.19.8-100.fc42.x86_64
[OZH@fw-13]~% dmesg | grep iwlwifi
dmesg: read kernel buffer failed: Operation not permitted
[OZH@fw-13]~% sudo dmesg | grep iwlwifi
[ 6.035435] iwlwifi 0000:c0:00.0: enabling device (0000 → 0002)
[ 6.047305] iwlwifi 0000:c0:00.0: Detected crf-id 0x3617, cnv-id 0x100530 wfpm id 0x80000000
[ 6.047340] iwlwifi 0000:c0:00.0: PCI dev 2723/0080, rev=0x340, rfid=0x10a100
[ 6.047342] iwlwifi 0000:c0:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz
[ 6.075938] iwlwifi 0000:c0:00.0: loaded firmware version 77.f39cc7f9.0 cc-a0-77.ucode op_mode iwlmvm
[ 6.416273] iwlwifi 0000:c0:00.0: Detected RF HR B3, rfid=0x10a100
[ 6.490961] iwlwifi 0000:c0:00.0: base HW address: 60:f2:62:3d:ba:44
[ 6.517515] iwlwifi 0000:c0:00.0 wlp192s0: renamed from wlan0
[ 65.336517] WARNING: drivers/net/wireless/intel/iwlwifi/pcie/gen1_2/trans.c:2387 at __iwl_trans_pcie_grab_nic_access+0xf1/0x150 [iwlwifi], CPU#4: kworker/u64:44/4353
[ 65.336606] snd_hda_codec_hdmi intel_rapl_common snd_soc_core snd_hda_intel snd_compress mac80211 snd_hda_codec ac97_bus edac_mce_amd uvcvideo snd_pcm_dmaengine snd_hda_core snd_rpl_pci_acp6x uvc kvm_amd snd_intel_dspcfg btusb libarc4 snd_acp_pci videobuf2_vmalloc snd_intel_sdw_acpi btmtk snd_amd_acpi_mach snd_hwdep videobuf2_memops leds_cros_ec kvm snd_acp_legacy_common videobuf2_v4l2 btrtl snd_seq iwlwifi cros_kbd_led_backlight cros_ec_sysfs hid_sensor_als led_class_multicolor cros_ec_chardev gpio_cros_ec cros_charge_control cros_ec_hwmon snd_pci_acp6x videobuf2_common btbcm snd_seq_device hid_sensor_trigger snd_pci_acp5x btintel hid_sensor_iio_common snd_pcm amd_pmf irqbypass cros_ec_dev snd_rn_pci_acp3x industrialio_triggered_buffer snd_timer videodev cfg80211 bluetooth amdtee rapl spd5118 kfifo_buf snd_acp_config snd industrialio mc cros_ec_lpcs i2c_piix4 pcspkr snd_soc_acpi wmi_bmof k10temp amd_sfh cros_ec soundcore rfkill snd_pci_acp3x i2c_smbus tee cros_ec_proto amd_pmc platform_profile joydev loop nfnetlink
[ 65.336706] RIP: 0010:__iwl_trans_pcie_grab_nic_access+0xf7/0x150 [iwlwifi]
[ 65.336745] iwl_trans_pcie_grab_nic_access+0x1f/0x50 [iwlwifi]
[ 65.336756] iwl_write_prph_delay+0x1f/0x60 [iwlwifi]
[ 65.336768] iwl_pcie_rx_stop+0x2f/0xc0 [iwlwifi]
[ 65.336782] iwl_trans_pcie_gen2_stop_device+0x357/0x370 [iwlwifi]
[ 65.336801] iwl_trans_stop_device+0x3e/0xd0 [iwlwifi]
[ 65.336817] ? iwl_fw_dbg_stop_sync+0x25/0x50 [iwlwifi]
[ 65.336859] _iwl_pci_resume.isra.0+0x9f/0x1d0 [iwlwifi]
[ 65.336876] iwl_pci_resume+0x10/0x20 [iwlwifi]
[ 65.336942] iwlwifi 0000:c0:00.0: iwlwifi transaction failed, dumping registers
[ 65.336944] iwlwifi 0000:c0:00.0: iwlwifi device config registers:
[ 65.336946] iwlwifi 0000:c0:00.0: Read failed at 0x0
[ 67.148587] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 67.148739] snd_hda_codec_hdmi intel_rapl_common snd_soc_core snd_hda_intel snd_compress mac80211 snd_hda_codec ac97_bus edac_mce_amd uvcvideo snd_pcm_dmaengine snd_hda_core snd_rpl_pci_acp6x uvc kvm_amd snd_intel_dspcfg btusb libarc4 snd_acp_pci videobuf2_vmalloc snd_intel_sdw_acpi btmtk snd_amd_acpi_mach snd_hwdep videobuf2_memops leds_cros_ec kvm snd_acp_legacy_common videobuf2_v4l2 btrtl snd_seq iwlwifi cros_kbd_led_backlight cros_ec_sysfs hid_sensor_als led_class_multicolor cros_ec_chardev gpio_cros_ec cros_charge_control cros_ec_hwmon snd_pci_acp6x videobuf2_common btbcm snd_seq_device hid_sensor_trigger snd_pci_acp5x btintel hid_sensor_iio_common snd_pcm amd_pmf irqbypass cros_ec_dev snd_rn_pci_acp3x industrialio_triggered_buffer snd_timer videodev cfg80211 bluetooth amdtee rapl spd5118 kfifo_buf snd_acp_config snd industrialio mc cros_ec_lpcs i2c_piix4 pcspkr snd_soc_acpi wmi_bmof k10temp amd_sfh cros_ec soundcore rfkill snd_pci_acp3x i2c_smbus tee cros_ec_proto amd_pmc platform_profile joydev loop nfnetlink
[ 67.149330] snd_hda_codec_hdmi intel_rapl_common snd_soc_core snd_hda_intel snd_compress mac80211 snd_hda_codec ac97_bus edac_mce_amd uvcvideo snd_pcm_dmaengine snd_hda_core snd_rpl_pci_acp6x uvc kvm_amd snd_intel_dspcfg btusb libarc4 snd_acp_pci videobuf2_vmalloc snd_intel_sdw_acpi btmtk snd_amd_acpi_mach snd_hwdep videobuf2_memops leds_cros_ec kvm snd_acp_legacy_common videobuf2_v4l2 btrtl snd_seq iwlwifi cros_kbd_led_backlight cros_ec_sysfs hid_sensor_als led_class_multicolor cros_ec_chardev gpio_cros_ec cros_charge_control cros_ec_hwmon snd_pci_acp6x videobuf2_common btbcm snd_seq_device hid_sensor_trigger snd_pci_acp5x btintel hid_sensor_iio_common snd_pcm amd_pmf irqbypass cros_ec_dev snd_rn_pci_acp3x industrialio_triggered_buffer snd_timer videodev cfg80211 bluetooth amdtee rapl spd5118 kfifo_buf snd_acp_config snd industrialio mc cros_ec_lpcs i2c_piix4 pcspkr snd_soc_acpi wmi_bmof k10temp amd_sfh cros_ec soundcore rfkill snd_pci_acp3x i2c_smbus tee cros_ec_proto amd_pmc platform_profile joydev loop nfnetlink
[ 67.176532] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 67.180930] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 67.181295] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 77.790582] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 77.790911] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 83.149993] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 83.150321] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 83.158237] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 83.158540] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 93.791060] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 93.791359] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 103.790547] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 103.790794] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 113.790739] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 113.790922] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 123.790417] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 123.790601] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 133.790426] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[ 133.790647] iwlwifi 0000:c0:00.0: Error, can not clear persistence bit
[OZH@fw-13]~% journalctl -b -1 | grep iwlwifi
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: enabling device (0000 → 0002)
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: Detected Intel(R) Wi-Fi 6E AX210 160MHz
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: loaded firmware version 89.123cf747.0 ty-a0-gf-a0-89.ucode op_mode iwlmvm
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_AUTH_KEY_0: 0x90
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: Detected RF GF, rfid=0x10d000
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0: base HW address: 40:d1:33:58:28:57
Mar 17 18:40:00 fw-13 kernel: iwlwifi 0000:c0:00.0 wlp192s0: renamed from wlan0
Mar 17 18:40:01 fw-13 NetworkManager[1311]: [1773726001.9655] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:02.3/0000:c0:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
Mar 17 18:40:02 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
Mar 17 18:40:02 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Mar 17 18:40:02 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_AUTH_KEY_0: 0x90
Mar 17 18:40:02 fw-13 kernel: iwlwifi 0000:c0:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
Mar 17 18:42:24 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
Mar 17 18:42:24 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Mar 17 18:42:24 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_AUTH_KEY_0: 0x90
Mar 17 18:42:24 fw-13 kernel: iwlwifi 0000:c0:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
Mar 17 18:42:25 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
Mar 17 18:42:25 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Mar 17 18:42:25 fw-13 kernel: iwlwifi 0000:c0:00.0: WFPM_AUTH_KEY_0: 0x90
Mar 17 18:42:25 fw-13 kernel: iwlwifi 0000:c0:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
I suggest you bisect the kernel to figure out what caused this and then report your results. Otherwise the iwlwifi driver maintainers might have no indication there is such an issue.
A strange development has prevented me from bisecting the kernel, now seemingly all kernels, including my previously safe 6.18.13 have started exhibiting my issues. Even a Timeshift restore to before I started bisecting doesn’t fix the issue.
I’m at a loss, to be honest.
linux-firmware regression perhaps?
Definitely seems like it but I currently can’t put the work into finding the commit where it started/collecting evidence as it will compromise my studies. I’ve been able to restore 6.18.13 functionality now by reinstalling the kernel and appending all the stuff to GRUB_CMDLINE_LINUX. I was apparently wrong before about that not doing anything.
What else can I collect to help the linux-firmware maintainers fix the issue?
I’ve also been thinking about fresh installing Fedora 43 onto my system, since I can’t get the 42 to 43 upgrade working anyway. That’s got a chance of fixing it right?
You should be able to look at your package install history and see if the problems started when you had an upgrade to the firmware package. If so - you will know the specific firmware package to roll back and check.
Resolved roundaboutly by reinstalling Fedora to get myself onto 43. Wahoo!
