Hi! I’m having an issue where there is no option to view the CPU temperature metric in AMD Adrenalin. The only available metric for CPU is utilization. Is anyone else having this issue? Thanks! Running the Ryzen 9 7940HS.
Yep. I’ve noticed this on the Framework-specific Adrenalin driver. If you use the one directly from AMD however, all metrics are available.
Thank you!!
