When powering on my Framework (DIY Intel 12th Gen), the screen stays dark and the LED on the right is blinking in different colors (I’ve only observed this once, there was defeinetly red and another color - I haven’t even realized before that this is an RGB LED).
When I press the power button again to turn it off and turn it then on again, the system boots regularly (I’m using Linux, but I guess this is a hardware issue).
Did anyone experience something similar and found a solution, so that the Laptop is booting on first power on?
Thanks ![]()
