Hello,
I need to remove a couple of parts from my pre-order, so I sent an e-mail to support@frame.work the other day but never received a response. Is there a number that I call to talk to an order specialist?
Thanks,
Joseph
Hello,
Thanks,
Joseph
Hi Joseph!
I’m so sorry for the confusion! I have searched our system and I do not see any email from you at this time. I do see your order in our system. Would you mind sending me an email with what you’d like updated? If you don’t mind please use the same email you used to place your order as well. Looking forward to hearing from you!
Thanks so much for your patience as well
Thank you for the prompt reply, Jehan. I have resent my request to support@frame.work.
In case it doesn’t come through again, the components that I want to remove are the SSD and RAM. (I found them on sale at Amazon.) Thanks!
Jehan took care of this. Thanks again!
