I’ve been frustrated with removing cards from the MicroSD expansion card… To the point that I’ve decided to replace the connector with a push-push spring-loaded one… I just can’t find the specific (original) slot, or anything like it for that matter.
From what I’ve gathered:
It’s a UHS-II slot, so it has 10 pins in the front, and 9 in the back
It measures 13mm * 11mm * ~1.5mm (I don’t have a caliper)
Notably, this makes it about 5mm shorter than a standard off-the-shelf MicroSD slot
8mm / 9 = .88 pitch (Once again, no caliper)
(Distance between left edge of pins 1 and 10 divided by gaps between pins)Photo Reference:
Any direction to finding this part (or a replacement) would be much appreciated. ![]()
