Hi,
I have a little trouble with keeping my framework clean. As soon as I touch it, there are fingerprints. Do you have a solution for that or am I wierd that way?
My old laptop was made from plastic and didnt show fingerprints like that. Dont get me wrong, the framework feels much better. I just dont like the fingerprints everywhere…
Thanks for your help
I also get sweaty finger after a while, so I would have to stand up and wash my hands every 20 mins or so. Thats not really an option for me.
Below the keyboard and on the back of the screen.
Its not really a problem, I just wanted to know if there is a way around this.
Maybe I just have to clean it every few days.
This might be a defective keyboard cover. Check with the FW team. I don’t have the same problem, but it might be worth it to try a dbrand skin. (Vinyl on op of FW aluminum)
That’s typically how fingerprints work; you touch something, your fingerprints are left behind.
