Question about the 16 and any docking solution
Dear Framework,
Hope this finds you well. I just ordered the framework 16 with the 180 watt power brick and I was wondering if you plan on releasing a docking solution for the framework so I don’t have to unplug and replug up my laptop as well as a dock every time I want to work on a larger screen.
I’m a big fan of the “one cable, one plug” solutions.
Anyways, please keep up the good work, and keep fighting for Right to repair. Thank you.
TomB.
Framework rarely talks about their future plans, although I would certainly be interested if they released a dock that used their modules and supported USB PD 3.1 EPR charging.
Afaik currently the only dock that supports USB PD 3.1 EPR (the fast charging protocol that Framework uses) is the dock integrated into the Lenovo Y34wz-30 monitor, however that only supports 140w (not 180w) and is only available integrated into the monitor.
Thank you for responding. Do you have a link for that dock?
