Is there a USB-C dock that can deliver enough power for the FrameWork 16 yet?
I’ve had no luck searching for such a thing; the highest amount of USB-C Power Delivery I can find in a dock isn’t enough to cover the FW16 with a discrete GPU. “Everyone” seems to produce docks with enough juice for Apple systems (makes sense, big market), but the closest currently seems to be Dell’s " WD19S 180W" which can only supply 130W.
That Dell dock uses a proprietary protocol above 100W, not EPR. I have seen a Dell monitor which was 140W with EPR, but that’s the only Thunderbolt dock I know of with it.
Frameworks 180W PSU, as far as I’m aware, is the highest delivery available on the market right now over usb pd. It is not enough to power the device under high load, as you say. For better or worse, it’s part of the gamble they’ve made with betting on the future.
that charger was also basically impossible to get hold of outside of the chinese market (it was for a phone iirc, not sure how a phone battery can even charge off that much power without exploding). for all i know its also just a proprietary protocol anyway.
as for docks i dont reckon you would be able to get more than 140W at the highest end (like most usb-c pd stuff on the market right now)
With you on this, I eagerly await a good quality dock with full EPR passthrough or built-in PSU. When I last searched for it couple months ago, I didn’t find anything at all.
Decided to give it a go, and only found this one, which claims that it can negotiate up to 140W (5A@28V) and pass through 130W (4.65A@28V).
My use case is fine with 90W charging while I work, and when I game, I can plug in the 180W charger, so I’m going to wait until I can buy a dock which can supply or pass through the whole 48V.
There is a Delta Electronics branded 240W PD EPR ‘available’ that Framework tweeted about back in (I think) August.
I ordered one from Mouser a while back, and got a delivery update email today, shifting the delivery date forward to the first or second week of Nov (previously it was the end of Nov).
I don’t recommend anyone be like me and buy it, until after reviews and 3rd party testing can verify it won’t kill your gadgets. That being said, there are a few non-AliExpress/AliBaba sources for it if anyone else ignores me and wants to buy/try their own.
I have no idea what it is coming with (just a brick, with detachable cables, just a USB-C cable and you have to source your own country specific plug, etc), which again should temper some impulse buyers.
I got mine from DigiKey, and it’s a Delta PSU. So far so good.
I have a USB-C power tester tool but it can only negotiate and detect 140W PSUs, so it also states that I have a 140W PSU with the Delta 240W. It says the same for the FW 180W PSU.
I can confirm it is drawing 230W from the wall when I’m at full tilt (Cinebench 2023 and FurMark at the same time). It drops to 160W if I set Windows to Balance Mode, which is what was recommended for use on the 180W PSU (and now I see why that is).
Now I see why the 180W was not enough to keep the battery untouched while at full tilt.
Unfortunately, I don’t know of any docking stations that can provide anything past 140W, mostly because Apple have laptops uses 140W USB-C PD and everyone will start making accessories if Apple uses it. I don’t think Framework has the reach to convince large USB PSU makers to make anything beyond 140W for now.
My CalDigit TS4 supplies 100W and it’s enough to keep the laptop from draining the battery on light work, but not so much heavy CPU or GPU loads. I could plug in the 240W PSU in a second USB-C port on my laptop - they don’t add up, only the more powerful PSU gets used.
I’m not sure if everyone would count this as a dock, but I got an HP Omen Transcend 32 OLED. It is a monitor, but has replaced my old dock because it has quite a few USB ports and, most notably, provides 240 watt power delivery
Huh, I didn’t think it was 240 before I bought it, but found it was 240 when I set it up. Now I’ll have to check again, but probably misread something. Maybe my brain swapped with the 240hz refresh rate
I got it, I use it, it works. I often use a 100W for day-to-day use, and only use the 240W charger when doing heavy gaming, or when the battery is very low and I need to charge as much as possible when time-constrained. In general, I try to extend my battery life by using lower wattage chargers when possible.
It comes as a brick without a detachable wall cord (uses the same wall cord as the 180W Framework charger), but does have a non-detachable USB cable.
Many people have done far more testing than me, and have reported generally positive reviews; though, some have found possible bugs in the Framework PD charging logic/power distribution at 240W when trying to stress the system (either through gaming or simulated workloads/benchmarks).
