Read/Write Performance of the Framework Expansion Storage Drives
Does anyone have some crystaldisk performance benchmarks of the (currently out-of-stock) 1TB storage expansion cards?
Im curious to what their performance is and also the chip supplier. My goal is to get one of these (or simply make my own) to run a separate bootable OS from.
-Nineball
I have the 250 GB version if that interests you but not the 1TB version. Let me know is you’d like benchmarks of it.
Sure!
Ok, I’ll run and post them when I have some time (likely this weekend).
Note that both 250GB and 1TB storage cards have a 1st Gen and a 2nd Gen version.
There’s some info there on the wiki and its linked sources. It has some speed numbers for all four versions.
According to that page, and Nirav’s original blog post about the storage:
  • Phison U17 Flash controller for the 2nd Gen (and I think also for 1st Gen)
  • Micron N28 NAND in 1st Gen storage expansion cards
  • Hynix V6 NAND in 2nd Gen storage expansion cards
I think booting from the 1nd Gen expansions was generally unstable. If I recall right, that was considered resolved in the 2nd Gen. Since you’re going to boot from them, I’d skip all 1st Gen cards, and you should look for something more authoritative on booting from the 2nd Gen.
Edit to add: the Framework store page implies that 1st Gen 1TB cards are okay for booting the OS. It’s possible the problems I remember were only on the 250GB card. I don’t have direct experience with it.
Thanks for the information. Looks like 2nd gen it is.
Additionally, Are there any known third-party expansion bay storage drives out there besides Framework’s that maintain the look? I was originally going to design my own PCB with controllers, with a type-c pass-through to make it look discrete but it simply just wasn’t cost effective.
Here are the results for my 250GB drive (32% full at time of testing). I left all of the Crystal Disk Mark settings at their defaults. Let me know if you’d like to see the results of a specific test. The back of the card says “250 GB Expansion Card FRACCFBZ02-2 (2nd Gen)”.
Looks pretty decent.
Hopefully the 1TBs come into stock soon..
yeah and the 1 TB (1 Gen) I have it and i think its faster then the 2nd Gen I havent tested it but i use it all the time and it feels automatic!
