I’m considering buying the framework desktop and am curious about the remote restart options available. I currently use jetkvm and would like the ability to reboot the computer remotely in case it is frozen and locked up.
This Card is designed to enable this, but it isn’t clear if that is even a viable option for the framework desktop.
What are the recomendations/experience people have?
Pro: More integrated experience, everything can be done through JetKVM
Con: It doesn’t seem like this is easy to do at the moment, I’d want to also see other peoples experience with another case in terms of what the thermals and noise are.
I think I would go with option 1 if I were to pull the trigger on buying this today.
